1 - 6 of 6 Posts
Vendor
Give your Alfa Romeo Stelvio that "Woosh" blow off sound with this simple to install and very affordable Blow Off Adaptor Plate from SILA Concepts.
This easy to install Blow Off Adapter Plate by SILA Concepts is designed specifically for the Alfa Romeo Stelvio 2.0L to use with the OEM solenoid valve to generate that unmistakable turbo dumping sound.
For the full details on the SILA Concepts Blow Off Adapter Plate for your Alfa Romeo Stelvio please visit the link below:
Alfa Romeo Stelvio 2.0L Blow Off Adapter Plate by SILA Concepts - MADNESS Autoworks - Auto Parts and Accessories
Vendor
Discussion Starter · #2 ·
Vendor
Designed specifically for the Alfa Romeo Stelvio 2.0L, the SILA Concepts Blow Off Adaptor Plate is a directy bolt on part, that does not trigger Check Engine Lights and is fully reversible should you ever wish to remove.
For more information on the SILA Concepts Blow Off Adaptor Plate for your Alfa Romeo Stelvio please visit the link below:
[/QUOTE
Can this work with the Go Fast Bits DV+
Vendor
Hello Bazil,
Thank you for reaching out to us.
In theory the SILA Blow Off Plate can be used with the DV+ by Go Fast Bits.
We offer the two as a bundle for other vehicles.
This does require different extended bolts to go through both products. We don't offer the bundle on the 2.0L Stelvio as we haven't located a reliable source for the hardware that will work with 2.0L Alfa engine.
If you are confidant in your local hardware store's ability to provide the extended screws the two can be mounted together.
If there is anything else we can do please don't hesitate to reach out to us directly and one of our Team Members will be happy to help.
Hello Bazil,
Thanks for the reply!
1 - 6 of 6 Posts
