1 - 15 of 15 Posts
Vendor
Today is a very special day as we get to let you see what we at MADNESS have spent the last six months working on!
The very first custom-made direct factory replacement full carbon fiber intake box!
We just fitted the final prototype to our Stelvio and the final version should be available to order in the next 30 to 45 days!
The box completely replaces the original factory box and houses an entirely new filter. The filter has been upgraded from a flat panel to a large diameter double cone.
Which is then completely enclosed in the carbon box allowing it to scoop cold air from the intake tubing and not the hot air in the engine bay. This also helps to keep the filter cleaner longer and add the custom look under the hood.
Has you can see, the new box is much smoother than the factory one which allows the engine to breathe easier and increase power.
We also did not move or relocate any of the sensors. The mass air flow is still in the original location, orientation, and order. So we have not seen any errors or check engine lights as a result of this upgrade.
Let's do a carbon fiber engine cover also for the 2.0...!!! To replace the factory plastic rag !!! D
Vendor
Discussion Starter · #6 ·
COMING JULY 2018
Our new MAXFlow Carbon Fiber Intake System is designed to deliver performance gains, improved sound along with show stopping looks.
The MAXFlow Carbon Fiber Intake System features a custom made housing that is manufactured out of 100% Genuine Carbon Fiber. The housing is finished with a high gloss clear coat for a showstopping look that is second to none.
The MAXFlow Carbon Fiber Filter Housing is designed to link up with the original factory front air inlet of your Alfa Romeo Giulia. This design allows for clean, cold air coming in from the front air inlet opening to be routed directly in to the new airbox. The factory air inlet was designed for maximum efficiency by Alfa Engineers and we designed our system to take advantage of this design.
More information to come
Vendor
Discussion Starter · #8 ·
As we advise all of our users: it's not products themselves that impact warranty, but a Service Manager's discretion. We have a number of dealer partners across the US who are aware of what we offer, and many of them work together with us, even installing our products for clients (I won't name names, for obvious reasons).
The best course of action is to have an earnest dialogue with the decision maker at your dealership. Most places are OK with simple changes.
The MAXFlow Carbon Fiber Filter Housing is designed to link up with the original factory front air inlet of your Alfa Romeo Stelvio and retains the factory sensor.
The MAXFlow Carbon Fiber Intake System comes with all hardware needed for an easy direct bolt on conversion and is completely reversible. Just hold onto the factory intake and swap it back in if you'd like to.
If you have any other questions please do reach out and contact us.
Vendor
Discussion Starter · #13 ·
Is there any performance gains? Louder intake sound? Does the filter have to be oiled like a k&n filter?
With the MAXFlow Intake System installed you will get performance improvements over stock. Our system starts with a better filter that was born and continues development around motorsports while being the filter of choice for champions of numerous series including Formula 1 and GT. That filter is also much larger and a double cone allowing for more air to flow through it.
Yes the BMC filter is an oiled filter.
Around that filter, we built a smoother housing to reduce turbulence. This housing also takes in cold air from in front of the bumper to supply the turbo with the coldest cleanest air possible.
So we can tell you that you will get an improvement, you will feel it, and you will hear it.
Vendor
Discussion Starter · #15 ·
Improve the airflow and performance of your Alfa Romeo Giulia with the new MAXFlow Carbon Fiber Intake System!
Housed in a completely custom and hand made carbon fiber intake, the new BMC double cone filter will allow more air, cleaner air. and colder air into your turbo than other intakes! By hooking into the factory bumper scoops the MAXFlow system is able to provide your turbo with the coldest air possible!
More information can be found on our website
https://madnessautoworks.com/2018-A...system-w-bmc-twin-air-connical-filter-pid8057
Let us know if you have any questions
1 - 15 of 15 Posts
