1 - 6 of 6 Posts
· Vendor
Attention all Alfa Romeo Stelvio owners! Are you looking to take your driving experience to the next level? Look no further than the Corsa Forza Performance Lower Subframe Brace, available exclusively at AlfaAffair.com.
The Alfa Romeo Stelvio is already a high-performance vehicle, but there is always room for improvement. The Lower Subframe Brace from Corsa Forza Performance is designed to improve the handling and stability of your Stelvio, allowing you to take on corners with more confidence and control.
The Lower Subframe Brace is made from high-quality materials and is engineered to fit perfectly with your Alfa Romeo Stelvio. It is easy to install and once installed, you will notice a significant improvement in the overall feel of your Giulia.
Take your Alfa Romeo Stelvio to the next level with the Lower Subframe Brace from Corsa Forza Performance, available now at AlfaAffair.com. Order yours today and experience the difference for yourself!
alfa, Stelvio, romeo, brace, front, chassis, corsa, forza, cfp,sub,frame,subframe,lower,tie,bar for Alfa Romeo
· Vendor
Discussion Starter · #4 ·
Is this for the 2.0 only or 2.9 as well?
Hello DJPete,
Thank you for reaching out to us.
This Sub Frame Brace is for all Stelvio models! We have installed them on both 2.0 and 2.9 here in the shop.
If there is anything else we can help you with, please don't hesitate to give us a call at 512-982-9393 TX or 562-981-6800 CA and one of our Team Members will be happy to help.
· Vendor
Discussion Starter · #6 ·
How is it with lowered Stelvios? 🤔
Hello AlfaAF,
The stiffening should be as noticeable or better for lowered Stelvios.
The brace tucks up pretty well and only protrudes half an inch or so over the factory felt under panels, so it shouldn't effect ground clearance too much.
If there's anything else we can help you with, please don't hesitate to give us a call at 512-982-9393 TX or 562-981-6800 CA and one of our Technical Advisors will be happy to help.
Thanks again.
1 - 6 of 6 Posts
