Good information @Stelvio PR thanks for sharing!
I wouldn't go that route unless strictly necessary, after all I can afford the mirror assembly. But, if it happens again I might just do what you are suggesting.random example
temp sensor mirror
another one
If you're handy, you can even just buy an NTC thermistor with the correct value for very little at an electronics store, and pot it yourself with f.i. some sillicone kit
I believe standard value required is 10 kOhm
I just saw the links, those are the right ones. The same used on a Jeep Renegade, Fiat 500X,RAM, and other FCA vehicles.random example
temp sensor mirror
another one
I see that one has like a clip in the front for a screw or to clip to a post. I have seen others that don't have that clip. Can you take a picture of the original one? The one you replaced? ThanksThanks All - So I bought a new sensor and fitted it (not a particular hard job), and I'm assuming its a standard 10k thermistor. It had the right number - 71753245 - here was the link - New Sensor, exterior temperature, 71753245 60779278 06445F9 6445.JS 6445.F9 | eBay
My temperature now is showing at 50'C (it does work though from putting it in ice it drops 10'C and then warms up ok).
Does it need calibrating though? As obviously at the moment its about 40'c out?
Any thoughts?
Matt
Thanks for your help! All sorted now.....tried a different ebay sensor - Ambient Temperature Sensor Underneath Door Mirror For Fiat 500 500X 500L Punto | eBay and that fixed it.....I see that one has like a clip in the front for a screw or to clip to a post. I have seen others that don't have that clip. Can you take a picture of the original one? The one you replaced? Thanks
Thanks for your help! All sorted now.....tried a different ebay sensor - Ambient Temperature Sensor Underneath Door Mirror For Fiat 500 500X 500L Punto | eBay and that fixed it.....If possible I would measure the resistance of the thermistor with a multimeter..... Could still be wrong nominal value.....
there's no calibration....
specially as it is not a rare happening for the sensor to failJust to say this was an easy fix and saved piles of money.....pretty rubbish that Alfa's fix is a whole new wing mirror at £400+ and then fitting!
2nd post of this thread..Got the same problem on my 2018 Stelvio TI (Canada).
What is the exact part number for that bloody sensor I must get?
My dealer told me it will cost me $1355 plus labor to replace that side mirror.
Be careful, from what I understand this is not the one. This one has a tab/clip for a screw. This type has a different Ohm rating and will read differente. Read further above for the right one, it was posted by someone else. I will post anyways.
Otto, this is the correct one: Brand New - Fiat 500 C X L Outside Temperature/Ambient Sensor Underneath Mirror | eBay
