1 - 4 of 4 Posts
2018 Stelvio. Listening to audio from iPhone via bluetooth. If I plug into one of the USB ports to charge the phone, the system switches over to USB, which is fine. But after about 30 seconds, it drops the connection and the infotainment system says “connect a device”. This is maddening!! Is there a setting or something to turn this function off?
Moderator
You could get a USB charger that plugs into the 12 volt outlet. That would charge your phone but it wouldn't be a USB connection.
Thanks Tom, that’s what I’m doing as a workaround. I just don’t get the system dropping my phone as a media source after it clearly has it up and running for about 30 seconds. It just feels like some buggy software at play. I don’t know. For the money spent on the car, I feel like everything should kinda work as intended. Thanks again for the reply.
1 - 4 of 4 Posts
