1 - 16 of 16 Posts
I ordered the new Stevio 2020 to replace my current one which is from 2017.
I asked my dealer if he could mount me before delivery 4 QV rims in 255/45/20.
Categorical refusal.
Such a modification would void the manufacturer's warranty.
The standard Stelvio is not designed to be fitted with QV rims
I have run them for 2 years 255/285 setup. You do not want to run 255's on rear. Tires will be stretched. That may be their issue. Your fitment choice is incorrect.
Reactions: lost1750GTV
Discussion Starter #4
Try another dealer ;)
The dimensions of the tires on a standard Stelvio in 20 "(255/45/20) correspond well to the front tires of a QV. But the offsets are different. My dealer before answering me to ask Alfa Romeo France. Refusal.
Discussion Starter #6 (Edited)
The dimensions of the front tires of the QV (255/45/20) are identical to those of the 4 tires of a Stelvio Standard.
So I thought we could mount 4 front rims from QV on a Stelvio Standard but Alfa Romeo France refuses because of different offset.
They said this could cause problems on the running gear.
Alfa Romeo refuses just as much the fitting of the rear wheels of the QV (285/45/20) to the rear on a standard Stelvio.
I found on an Italian forum a Stelvio owner to whom we made the same answer
Greetings to all. I went to the dealer for the winter / summer tire change. As I said earlier, I had bought the 20 "cloverleaf set (which has as ref. 5YN), 9.0Jx20" ET29.
(As you well know the stelvio mounts the type 8.5Jx20 "ET31, ref.5A6 as 20").
Short, the difference is small and the dealer thought it worked. Today he explained to me (from what I understand, I'm not an expert, sorry) that the problem is the distances with the brakes (very different between the four-leaf clover and mine). Essentially, the design of the rim is such as to leave room for the braking system, which on the Stelvio is at a certain distance from the axle and in the four-leaf clover to another (larger). In the case of four-leaf clover rims, it will therefore be necessary to move the wheels outwards by several millimeters. In the end we succeed, but they do not want to take responsibility for the change, because a Stelvio with the same changes has returned to the garage with bearing problems ...
What to tell you. Since I was refunded in full for a considerable amount (here we are in France and almost everything costs more), I have no reason not to believe in their good faith, even if I don't fully understand the explanation (more in French with technical terms ...). I have inserted two photos of the different rims where you can see the curvature at the brake in the "classic" case, while it seems that the brake is much closer to the four-leaf clover rim, whose "spokes" become much thicker, approaching the axle.
For those interested, the German catalog contains various information on the various models, https://www.alfaromeo.de/content/da...price-list/pdf/stelvio/Stelvio_Preisliste.pdf, page 9, where it seems there is incompatibility between 5YN and 5A6 (there is no price and no option).
Question. Some of you have mounted QV rims on a Stelvio Standard by mounting 4 rims in 255/45/20?
If yes, did you do it with or without enlargers
Could you buy the QV and have the whole package?
I am a client advisor at West German BMW and a Stelvio owner. That’s the same answer you would receive here. We can’t do it on a new car. It must be delivered as it was built.
Discussion Starter #11
My dealer and Alfa Romeo France have also indicated that if I had QV rims after delivery it would cause the forfeiture of the warranty in the event of a problem (suspension, running gear, bearings ...)
Quad rear wheels are wider so must run a 285. The wider wheels have plenty of room on the smaller standard rear brakes...non issue. Front calipers are close but a non issue. I have no issues with my TiSport and quad wheels in summer on the 3rd season now. . Last I checked, wheels don't flex. If you are running rubber sticky enough to do that you could probably destroy entire suspension...ie slicks on a track. Next BS they'll try is must use OE rubber. I do not run spacers. Tolerance to calipers is close but no worse than other vehicles I own. That's almost like saying any non stock wheel will forfeit warranty.. Wheel does not stick out thus causing bearing strain is not an issue. If anything, the higher quality tire's road holding ability would be the greater issue IMHO. I also know folks that run 4 front Quad wheels and run 255's all around that way.
Considering what punks do to their rides with camber etc, I would NOT be concerned about any ill affects
Ironic that my dealer in CT considers my setup the best looking they've seen between the color and black wheels. Zero issues with the wheels and have done it for several others.
Discussion Starter #13
Thanks for all the details. But, in my case, from the moment when the dealer and Alfa Romeo told me of their position I cannot mount QV wheels. In the event of a problem, they will remind me that they have warned me that the warranty will be canceled. The legislation is much stricter in Europe than in the United States on this type of subject ...
We get the occasional riot, but the US is still pretty cool:devilish:
If you bought it from Valenti, I’m not surprised. I worked as a tech at a Valenti dealership for a few years, have dealt with their Audi and Porche shops in North Haven and Watertown. Sorry for your choice of dealers if it was Valenti. Crooks at every turn.
Figaro....my experience with Valenti is !))% the opposite over an almost 30yr run with everything from Alfas to Isuzus, and Lotus. Giovanni took care of my 164L like it was his own. Not even sure what you'r saying as it doesn't remotely correlate with our European friend's issues. Valenti loves my cars
1 - 16 of 16 Posts
