1 - 20 of 64 Posts
This happens normally on cold mornings.
After a while once the engine warms up i turn the car off and back on again and it usually all clears.
Had the car from the Alfa dealer 5 months just.
Does anyone / has anyone experienced this or know what might be causing the issue.
2018 MY.
Thank you
GJ
Hi
yes i tried both on different occasions.
I drove for about 4 miles with the misfiring, pulled over in a garage stopped the car restarted and it was fine.
My 2018 Q4 did the same thing two different times right after startup within the first 100 meters of driving. It cleared after a restart. I changed the battery and sparkplugs. It hasn't done it since. But I think the gremlin is still there.
Discussion Starter · #12 ·
I was thinking coil packs too ! Maybe getting damp in the colder weather and the ECU shutting down that cylinder until a restart.
Ill be sure to send an update with findings.
New battery fitted about 4 weeks ago for upgraded AGM (hope its not that)
Motor vehicle Vehicle Automotive exterior Bumper Trunk
Tire Automotive tire Automotive lighting Motor vehicle Bumper
I don't know in the 4 cylinder but in the 6 cylinder that happens sometimes if you don't drive the car daily....its a PITA since then you need to go to the dealer to get the codes erased.....no DNA when that happens.....probably that has to do something with some oil leaking in a combustion chamber in the cylinder??....it can not be carbon build up.....
They redesigned the injection system last year I think.....now that wont happen. I just went today to the dealer to erase the codes.....I wish it could be retrofitted but probably that would be really costly.
When that happens I really WANT of getting rid of the car......until I accelerate in the causeway and leave everyone behind!!!......lol
My older quad doesn't get driven daily - and sometimes sits for weeks.
No trickle charger either.
I'd never rule out a bad battery or ibs for most anything on these, but if they are good then daily use or trickles arent necessary
2018 Alfa Romeo stelvio 2.0 Ti sport awd
Just took my car in the dealer today cause it had a engine light with the auto start stop disabled I plugged in the obdi my self it said cylinder 4 misfiring so waiting to see what’s that about since it started happing ever since 2 weeks ago when I took the car in for service to change the spark plugs serpentine belt cabin filter etc and the car only has 36K miles on it 🤦🏽‍♂️ At this point just thinking either ti sell the stelvio and lease a 2022 or a just go into a different brand
I told The service rep this today actually lol told me before I changed everything the car was fine after I changed all of that stuff I been getting misfires and engine lights for the past 2 weeks at first Bret said it was the sensor for the air filter that was loose which was bullshit but I told them this today to check the entire car to see what’s the issue they seem alittle In Competent at westbury alfa Romeo ( Long Island New York ) 🤦🏽‍♂️
Incompetent, and really inexperienced dealers are a real issue.
Hard to be competent when it's the first time you've encountered a problem.
Easiest way to diagnose your problem....
Code said misfire cylinder 4?
Ok, take the plug out of 4 switch it with any other cylinder, reinstall. See what happens. No need to wait for, or rely on the dealer really.
Yes code said cylinder 4 misfiring and at the same time your right it could be a simple issue or a major one but I believe it’s not since like I said it’s been happening ever since I changed the spark plugs serpentine belt cabin engine filter etc I’ll wait to see what the dealer tells me good thing is they put in a loaner so hopefully they can resolve the issue
The car already been there since the morning today so like I said Hopefully it’s a little issue and they can resolve it I was over there yelling and angry like my car been fine for 8 months ever since I got I bring it in for the scheduled services you guys recommended and spend over a 1K$ and now my car been misfiring and been in limp
Mode 3 times it’s ridiculous & on top of that they employees was reviving my car and speeding to “ test the car” cause of the exhaust I seen it on my dash cam 🤦🏽‍♂️
1 - 20 of 64 Posts
