Cluster Removal ?
277 Views 9 Replies 5 Participants Last post by  pocholin
Trying to remove the instrument cluster.
I have removed the steering wheel trim, and the small trim piece below the cluster.
I have removed the two torx screws holding the bottom of the cluster.
Supposedly it is now possible to pop out the cluster by pulling on it to unlatch the top two clips.
I have tried a number of ways, pulling very hard sometimes and it won't come out.
I think I was able to release the left clip, but not the right one.
It is very difficult to get a good grip to pull very hard, and I could not find anywhere to get a plastic pry bar in to help.
Any ideas or suggestions?
1 - 10 of 10 Posts
He doesn't show anything useful. In one frame the cluster is in place, and the next frame it is sitting on the passenger seat.
This one is a little more helpful. Around the 8 minute mark he is going through all the gyrations I tried. Finally, he cuts away, and comes back with it loosened.
Alfa Romeo Stelvio - come smontare lo Stereo e montare un Android 10" - YouTube
Try this video around 4:38 mark.. btw I found this guys series very educational.
removing cluster on Giulia is piece of cake.
...then we got Stelvio with it's SGW and cluster 😅
it's held by two screws at the bottom behind trim and two clips at the top. that's where the problem is as clips hold it too strong.
if you can't pull it then you'll have to remove lower trim in footwell, knee airbag and use some kind of pry bar, long screw driver or something similar to get from behind and pry it out. you'll be able to see back of cluster from bottom. just take your time because you can crack back of cluster when removing if you rush it.
It is a very tricky operation, one where you have to pull the cluster out hard but carefully.
In this picture, I have marked with circles the approximate area where the clips are for your information. You cannot see them or touch them until the cluster is out. I pulled the left side first as I had more room to do it. I used a flat screwdriver to help me. The "arrows" point to the place where I also use the same screwdriver to help with the right side.
I inserted the tip of the screwdriver in between the arrows, put my finger behind the screwdriver to create leverage (I hope that is the right word) and pull the cluster out of that clip. Hope this helps, good luck.
See less See more
yeah, the better part is him showing the back of the cluster, so one can see what it looks like, to see if there's anything that might be snagging?
Tried this. Got a pretty good grip and leverage. Applied a lot of pressure but couldn't free it. Very frustrating.
I understand, the first time it really feels like your going to break it. There's really only two clips holding it VERY tight.
Give it a rest tonight, tomorrow, start with the left side only, then the right side.
1 - 10 of 10 Posts
