1 - 20 of 26 Posts
Vendor
Give your Alfa Romeo Stelvio a more aggressive stance and improve the handling at the same time with these High-Quality Italian, Custom Wheel Spacers by Athena!
The combination of the best materials, special design, and precise manufacturing process make these custom wheels spacers the only choice when it comes to picking a set of wheel spacers for your vehicle. These spacers also come with TUV-Certified Hardware, because your safety is important!
Athena Custom Wheel Spacers are precisely machined from a block of top quality aluminum using CNC tooling machines to guarantee maximum precision. No welding is involved in this production process. This process gives the spacers unbeatable strength for an added level of safety.
Athena spacers for the Stelvio come in 5mm, 15mm 17mm, and 20mm sets with extended lug bolts.
More information and pricing can be found on our website
https://madnessautoworks.com/index.php?route=product/search&keyword=athena
Let us know if you have any questions
Vendor
Discussion Starter · #4 ·
Flush out the wheels on your Alfa Romeo Stelvio with a new set of Athena Wheel Spacers!
From the factory the wheels on a Stelvio sit pretty deep in the wheel well. These spacers from Athena are designed to fix that and give it a sportier look.
Available in several different sizes these spacers actually bolt to the hub so they will not slip during a wheel change.
More information can be found on our website
20mm
https://madnessautoworks.com/2017-A...acers-by-athena-20mm-set-of-2-w-bolts-pid7336
17mm
https://madnessautoworks.com/2017-A...acers-by-athena-17mm-set-of-2-w-bolts-pid7335
15mm
https://madnessautoworks.com/2017-A...acers-by-athena-15mm-set-of-2-w-bolts-pid7334
5mm
https://madnessautoworks.com/2017-A...pacers-by-athena-5mm-set-of-2-w-bolts-pid7337
Are black lugbolts available?
Vendor
Discussion Starter · #8 ·
Give your Alfa Romeo Stelvio a more aggressive stance with a set of custom-made wheel spacers by Athena!
These Athena spacers are Italian made, hub centric, TuV approved spacers.
They come in a variety of sizes but we typically recommend 17mm all the way around to get that flush look.
Each set comes with extended bolts.
Contact us directly or visit our website for more details
https://madnessautoworks.com/2017-Alfa%20Romeo-Stelvio/alfa-romeo-stelvio-wheel-spacers-by-athena-17mm-set-of-2-w-bolts-pid7335
Vendor
Discussion Starter · #9 ·
Get that flush look on your Alfa Romeo Stelvio with these custom Athena wheel spacers!
Athena makes some of the best spacers in the game right now and these carry TuV approval to certifiy their great build quality and materials.
These are hub centric spacers designed specifically for the Stelvio so there is no wiggle room once mounted. Which will ensure that your lugs to not bear the strain like other spacers.
Contact us directly or visit our website for more information
https://madnessautoworks.com/2018-A...acers-by-athena-17mm-set-of-2-w-bolts-pid7335
Vendor
Discussion Starter · #10 ·
Vendor
Discussion Starter · #12 ·
Any size suggestions for the Quad?
Depends what you are looking for! How flush do you want your wheels to sit with the fender?
Are you running your stock wheel and tire setup? Picture shows a 15mm spacer set on the front and a 17mm on the rear. If you are using your stock wheels and tires we recommend this combo.
Following links are the Athena products that we have to offer:
20mm
https://madnessautoworks.com/2017-Al...-bolts-pid7336
17mm
https://madnessautoworks.com/2017-Al...-bolts-pid7335
15mm
https://madnessautoworks.com/2017-Al...-bolts-pid7334
5mm
https://madnessautoworks.com/2017-Al...-bolts-pid7337
20mm
17mm
15mm
5mm
Is there any rubbing or bottoming out against the solid fender add ons with larger spacers?
Vendor
Discussion Starter · #16 ·
Give your Stelvio a more aggressive stance and improve the handling at the same time with these High Quality Italian, Custom Wheel Spacers by Athena!
Find the perfect fitment for your Alfa Romeo Stelvio by visiting the link below:
https://madnessautoworks.com/index....stelvio wheel spacers&filter_search_results=2
Vendor
Discussion Starter · #19 ·
Alfa Romeo Stelvio Wheel Spacers by Athena
CNC Machine production guarantees consistent and precise tolerances.
Anodized treatment to help prevent oxidation.
Sold in pairs to get the perfect fitment for your Alfa Romeo Stelvio no matter the size of your wheel package.
To find the Athena Wheel Spacers for your Stelvio please visit the link below:
Search - stelvio wheel spacer - MADNESS Autoworks - Auto Parts and Accessories
Vendor
Discussion Starter · #20 ·
For the full details on these Athena Wheel Spacers for your Alfa Romeo Stelvio please visit the link below:
Search - stelvio athena - MADNESS Autoworks - Auto Parts and Accessories
1 - 20 of 26 Posts
