1 - 5 of 5 Posts
Not that I used it much but I miss the DCS button. Wondering if there's way to deactivate the traction control on Stelvio.
It can be accomplished with a simple recode of the module and pre 2020 models require the dna switch be swapped to an rdna (2020+ can use their same switch).
It makes a huge difference. The figure 8 and skidpad results for our 2.0l is literally worse than the Toyota prius solely because it is esc restricted while the prius and most modern cars are not.
so rdna switch to 2018 models then recode? recode with what and how?
wow thank you. I was going to get MES anyhow and this looks pretty much easy!
1 - 5 of 5 Posts
