1 - 10 of 10 Posts
Just installed all 4 fender flares I ordered for a Quadrifoglio. Had them painted. Also installed 20mm rear wheel spacers.
Looks great!
Same setup that I have on mine.
Quick question for you-Perhaps it is the angle of the photo but there seems to be an excessive amount of camber on that rear wheel no?
I only drove it around the block after jacking it up. Hopefully it resets. If not it is a concern. Did you put on 20mm rear spacers as well?
Goose it from a dead stop. The weight transition from the acceleration should do it. If not....
It'll probably do it though!
I have 17 mm in the rear..
Couldnit find anyone with Black colored lugbolts except for Eurocompulsion who only has 17mm max
Discussion Starter #10
Think I'm going to paint the lugs high temp flat black. Unless I put 5mm spacers in the front. Not digging the silver lugs. I got mine from Madness Autoworks.
1 - 10 of 10 Posts
