I installed this on the QV for approximately 3k miles before switching to GFB option. I only did so because I was convinced that the Forge kit had a hand in the code P0F40 I kept having upon startup, but debunked this when I had the same code with GFB.
It ended up being the result of the QV being MY21 and the IdealRace intakes causing a EVAP code due to no sensor bypass. Eric since has found a solution via his flash tune and there is nothing wrong with either GFB or Forge Motorsports products working!
****NOT INCLUDING SHIPPING
