While my visor is up (in flat to roof position - buttons facing down) I'm finding you need to be almost touching the garage door / directly in front - few feet away before the door will open.
If you open the visor so the buttons are facing the windshield, the range of the signal dramatically improves and will open the garage door from 20-30 feet away...
where is the antenna mounted? can this be adjusted / improved??
