When you back out and then pull forward (shift from R to D), do you get the N gear from time to time if you are not extra careful, say you are in a hurry on a busy parking lot?
Correct, if you don't push the button when you shift it will cycle into N, but pressing the button then shifting it goes directly between P R and D depending on what direction you are looking for.Hasn't happened yet (unless I forget to push the front button on the stick).
So I'm not the only one. :grinI'm a N specialist, every 10 shift 3 go to N
