For best 0-60, should you use the paddles for upshifts or let the gearbox do it for you while on Dynamic mode obviously? I noticed the gearbox doesn't upshift by itself until ~5.5k rpm.
Can you brake torque it like the QV (brake pedal all the way down, followed by throttle pedal all the way down while holding the brake and then let go the brake)?use the "A-Fast" procedure.
place car in a closed street.
D, not manual.
left foot on brake, solid, the torque is too much.
bring the engine to 2500 rpm and stay still for 2 seconds, remove the brake and give the whole throttle. the system will manage all the changes automatically to the rpm limiter with the maximum efficency
