Agreed, they should work.... Something is wrong here.
Assuming they're the correct frequency and drove enough, they should work. You may need to pull the battery cable for a reset.
I also wouldn't discount the dealer pulling shenanigans prior to the install.
I just wanted to confirm this. Are you saying that if I rotate my tires, the infotainment just knows that I moved my front right tire to the rear left, for example, or do I need to update the computer somehow?It should automatically detect the location of the sensor, after some driving.
but yes, they should have corrected the pressures I guess![]()
Yes, they will adapt and pair on their own.I just wanted to confirm this. Are you saying that if I rotate my tires, the infotainment just knows that I moved my front right tire to the rear left, for example, or do I need to update the computer somehow?
Very interesting. I'm curious how that works. I guess they must have multiple receivers, one per tire. I'm used to a single receiver.Yes, they will adapt and pair on their own.
No programming or activation needed.
for general principle, see :Very interesting. I'm curious how that works. I guess they must have multiple receivers, one per tire. I'm used to a single receiver.
This is brilliant!for general principle, see :
In addition, there's the info from the ABS sensors of course.....
just to follow-up. replaced the other TPMS sensors above bought an amazon with these:yep have driven it around pleanty (100 miles)
sensors below:
I disconnected the battery last night and reconnected, aired up one of the tires to over 39psi to see if it would trigger something but nothing.![]()
Amazon.com: MORESENSOR Signature Series 433MHz TPMS Tire Pressure Sensor 4-Pack | Preprogrammed for Select 200+ European Brand Models | Replacement for 36106856227 | Clamp-in | NX-S004-4 : Automotive
Buy MORESENSOR Signature Series 433MHz TPMS Tire Pressure Sensor 4-Pack | Preprogrammed for Select 200+ European Brand Models | Replacement for 36106856227 | Clamp-in | NX-S004-4: Replacement Sensors - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
