Could be a tire pull, try rotating the front to the rear and vice versa. See what happens.
It is a quadrifoglio, so he can't rotate front to rear.Could be a tire pull, try rotating the front to the rear and vice versa. See what happens.
A slight pull to the right due to the crown of the road is absolutely normal. I’m surprised you wouldn’t be aware of this unless you are a very new driver.So… after owning and driving my Stelvio a couple months I’ve noticed the car has a tendency to drift to the right. And always needed to correct this so steering wheel is hardly never in the neutral position for very long. Brought it in for check up and was told the specs all check out and toe adjusted slightly. But on the drive home the car still behaves the same. Service center lady blamed this on the crown of the road which I had to look up. But the weird thing is, I drove their loaner Giulia and none of this sort of issue happened.
has any one experienced the same? And what to do next?
Having the steering wheel always having to turn slightly to the left also is a bit of an annoyance…
Ah.. yeah.... Things like this are why I hate staggered tires.It is a quadrifoglio, so he can't rotate front to rear.
