1 - 8 of 8 Posts
Any suggestions? I have an amber warning that the lane departure and forward crash prevention is not working
ACC/FCW not working check front camera. Auto high beam not available. These were working now not for any known reason. Is there something I should check before getting help from the dealer? (Check all the fuses).
I had a battery issue that triggered this exact same problem.
2 things you can remove the ground and it will cycle all the systems or put the battery on a very good tester/charger and see if it needs replacement.
Ian
Thanks Ian, I had unhooked the battery and it threw error codes, I think it may have caused the camera fault , but not sure it didnt happen before i disconnected the battery ???? i unhooked the battery when I installed my Seletron Chipbox.
OEM battery? I would buy a new one to be safe for future. I have seen a lot of vehicles do weird stuff with a inadequate voltage and or battery problems.
1 - 8 of 8 Posts
