1 - 4 of 4 Posts
1969 Alfa Spider 2016 Alfa 4c Spider 2020 Alfa Stelvio TI
2020 Stelvio Nav is not accurate anymore shows wrong streets but close by .Did reset not helped.
Any Ideas thx
Any Ideas thx
How do you do a reset ?
Anyway, assuming you have a clear view of the sky, I would suspect a problem with the GPS antenna ......
Sometimes driving, with sufficient turn-offs etc will reset the position, based on map matching
its sometime works correct than gets in to loop showing off streets and tries to correct it self but none happens and after stopping starts to work correct again.
Discussion Starter · #4 ·
I think i solved that there was global telematic module that stelantis pushed over
air. tsb 08-142-22. Its not just nav also all services with guardian not working like remote start car location etc
Alfa Romeo care dont have a clue.
lots of cars affected
1 - 4 of 4 Posts
