I tried this (pump gas pedal 5x, 3x, 6x times) a couple of times from last 2 days. Not been able to fix it. So strange.Try this from another post...
Steps:
I think that's exactly what happened with me. It's time for me to return the lease, and I just don't want Ally to charge me for something like this when it's not my fault. I wonder if it's my responsibility to change oil when there's enough oil in the car.The Stelvio seems to have two oil change counters. One based on miles, and the other based on time.
An example of the latter that has affected quite a few of us is shortly after we got our new Stelvio the oil change warning based on time appears. It is activated when one year has elapsed since the car was built. But in many (most?) cases, the new owner gets the car after it has been sitting in the dealer's lot for some months. For me, the warning showed up 4 months after I bought my Stelvio, but 1 year after the manufacture date on the door frame sticker.
It is likely that when they changed your oil they reset the elapsed miles warning but not the elapsed time warning.
Didn't work for me either. Is there a way to reset without going to dealer?I tried this (pump gas pedal 5x, 3x, 6x times) a couple of times from last 2 days. Not been able to fix it. So strange.
I was able to do it on my 18 ti sport. The trick is the timing of the actions, if you do it too fast it wont work and if you do it too slow it wont work. The Guilia forum has a good explanation of how to do it and I had previously posted the proceedure I followed to reset mine. I attempted it several times before I got it to work. It doesnt tell you when it resets, you have to check the counter. I think they could take a lesson from Ford or GM on this item.Didn't work for me either. Is there a way to reset without going to dealer?
I tried for 2-3 days, and suddenly it worked. I don't think it tells you right away it worked. I went on a drive for a few miles and then I noticed the annoying message went away.The trick is the timing of the actions
Exact same for me. Tried gas pedal 3 times method twice, gas pedal 5 times once and then found this post. Did brake 3 times and voila!FYI. I tried the gas pedal method several times wo success but then tried the brake pedal once and it worked.. key on...hit brake pedal 3 times quickly....start Veh...
Oh yeah, I have 2018 Stelvio TiExact same for me. Tried gas pedal 3 times method twice, gas pedal 5 times once and then found this post. Did brake 3 times and voila!
Neither method works for me - '19 TI Sport AWD.Exact same for me. Tried gas pedal 3 times method twice, gas pedal 5 times once and then found this post. Did brake 3 times and voila!
I can also confirm that this method worked on my '18 TI Sport, build date 5/18. The steps are:FYI. I tried the gas pedal method several times wo success but then tried the brake pedal once and it worked.. key on...hit brake pedal 3 times quickly....start Veh...
