1 - 3 of 3 Posts
I would not ignore the low oil message. Try adding about 1/2 pint more and see if that warning would go off. You would need MES to reset the maintenance oil interval and the oil change reminder but that alert should only show when you start the engine. There are those brake pumping techniques 6-7 times to reset the middle console maintenance required CEL but it appears to work in only few people.
Low oil warning is not the same as change oil reminder. Take it seriously.
1 - 3 of 3 Posts
