Key words: P0440, P0455, Evaporative emissions fault leak detected, Vapor Canister, Gas Cap, vapor canister Purge valve.
I want to get a thread going regarding how to get rid of "for good" the P0440 error code caused by a problem in the Evaporative emissions system.
Questions for the forum:
1. Can anyone post the service details from a 2019, and 2021 service manuals of the evap. system, to confirm that there was a design change?
(Post or send me the pages on how to service the vapor canister and purge valve, and lines that connect into the gas filler tube?)
2. Can someone post the P/Ns of the parts that the dealer replaces when they do this upgrade/repair?
3. Does anyone know of any other technique that can be used to resolve this problem?
No, I don't top off the gas tank, and gas cap was tested as being good by the dealer.
Thanks.
Background for those who want more details regarding my problem:
I started having the P0440 and P0455 errors a year ago during winter. I purchased the SGM bypass harness set and bypass module last spring. I was finally able to reset the error codes and track when they came back. The error messages came back until it warmed up in the spring, then all was well until the fall of last year, when the error codes started coming back again. (During this time, car was damaged in July from a large hail storm, and we needed a new windshield. Incorrect windshield was installed, then replaced. During this process, other error codes were set that the windshield installer had to clear, so they cleared all of the codes. We set up a dealer appointment in October to fix the problem under warranty. But guess what, the code never returned after the windshield installer cleared all the codes.
Therefore dealer couldn't fix a problem that can't be documented. In the mean time, our warranty has ran out and we decided to not purchase an extended warranty.
Then the same friggen code has returned...
- Goal and criteria is that the problem and parts can be replaced by the owner rather than the dealer. (My dealer stated that swapping the parts is straight forward and easy to do.)
- My 4 hour away Alfa dealer says this is the most common problem he repairs on Stelvios. 2nd most common is the problem with the instrument cluster.
- I want to purchase a service repair CD/USB drive, and they have been out of stock for months on the Mopar online parts site. (Why can't they just burn some more CDs or copy the files to a few thumb drives.)
- To date, I have found vapor canisters for sale online, but I can't find the vapor canister purge valve in stock anywhere.
- I was told that the lines to the vapor canister has been changed in later model years to help alleviate this problem, but I can't find any detailed information on this and it appears to be only known by the dealers, and my dealer wouldn't give me specific P/Ns.
Thanks.
