Anyone purchased from this company just bought the 60 HP chip hoping its worth it.
https://www.chipyourcar.com/product/alfa-romeo-performance-chips/
Thank you , I just want more HP than the 200 HP in Australia , but has made me think now. Thanks for reply.the marelli ecu can be write via odb2, no problem.
for my point of view the first thing to clarify is what's about new ecu firmware found, like my stelvio, with the last version ?
the differences are big.
for me is NO
Thank you so much , looks like a return to themone of the big problem with marelli is reading the ecu data and the engine map.
right now isn't possibile via odb2, only directly via the ecu.
when you have the firmware data you need to do a comparison with the old firmware data and bit position that every time change.
make a sync and adapt the correct map to the new firmware.
try to ask to the forum suppliers if they have a garage in australia for doing well this not so simple task
Forget getting a refund -This mob are con merchants .Thank you so much , looks like a return to them![]()
