At the 30k mile service on my ‘19 Stelvio Quad I was advised that the rear rotors (steel) are worn and need replacing soon… but the dealer can’t find any in the USA. That can’t be right. Anyone know if it’s true?
I certainly hope that’s not true.There are a couple after market options though. Tarox and girodisc I believe.At the 30k mile service on my ‘19 Stelvio Quad I was advised that the rear rotors (steel) are worn and need replacing soon… but the dealer can’t find any in the USA. That can’t be right. Anyone know if it’s true?
I'm not sure if anyone else has done this but I'm going to have a local (trusted) race fab shop resurface mine. I only need the rears done but he says he can "turn" cross-drilled/slotted/vented rotors. Will see once I get them off and check specs. So this might be another option if you cannot find any.At the 30k mile service on my ‘19 Stelvio Quad I was advised that the rear rotors (steel) are worn and need replacing soon… but the dealer can’t find any in the USA. That can’t be right. Anyone know if it’s true? Lol
i read somewhere that slotted and drilled rotors should not be resurfaced because they are pretty thin to begin with. Maybe they just said that so I would buy new rotors but prices were about the same. I just ended up buying new rotors each time.I'm not sure if anyone else has done this but I'm going to have a local (trusted) race fab shop resurface mine. I only need the rears done but he says he can "turn" cross-drilled/slotted/vented rotors. Will see once I get them off and check specs. So this might be another option if you cannot find any.
Not sure if they are "thinner" but the world has gone to just buying new ones because it was generally pretty cheap. Things are different on these cars, the stock rotors are expensive and two local shops told me they wouldn't turn cross-drilled rotors because it's hard on the cutting blades. I have read that in general slotted can be turned and just have to do it correctly.i read somewhere that slotted and drilled rotors should not be resurfaced because they are pretty thin to begin with. Maybe they just said that so I would buy new rotors but prices were about the same. I just ended up buying new rotors each time.
They are a single piece rotor. But they look as if they "vent" all the way through the the center of the disc, Probably the reason the (QV) is able to be run on a track. They can dissipate the heat faster. So I'm not sure if that will affect as to whether they can be resurfaced or not.Are your rotors 2 piece set up? I don't know anything about the 2 piece set up so you are probably right. I have a 2.0 with small vented brakes.... (slotted and drilled for now but going with regualr flat one next time)
I second his experiences, as long as they meet min thickness and braking is smooth right now, just put new pads and go easy on them for the first 200 miles or so.If brakes are operating smoothly , just buy new pads. I haven't resurfaced a rotor in well over 20 years. used to be what you did for minor warpage, but as far as grooves are concerned, just let new pads bed in. I track 15+ times a year, change pads all the time and only time i change rotors is when they are crazed a nd shot....long before they wear out. I had 80K rear rotors on my last X5 that were still well within spec, just reused them.
Simply get a micrometer and measure on vehicle. Takes 2 minutes. 95% sure they are fine. Min dimensions usually printed on hub
