Hi Flavio,
Sadly(for you) it's in Dutch, but i could recommend this company, they are experts in remapping the Alfa engins (Diesel and Petrol)
They have tested each engine and there conclusion is that each diesel is the same, i other words they can get a 150HP tot230HP as also the 180HP and 210HP.
Costs only 550 euro.
https://www.squadra-tuning.nl/chiptuning/alfa-romeo/stelvio/2-2-jtdm-210-pk-8at/
I'm considering it!
thats what I want to know too! any worthy engine upgrades for the 210hp diesel stelvio!Hi,
Did already someone remap the diesel version (210hp) ?
Thanks,
Flavio
thanks for the advice! i am opt to do the remap tuning or maybe performance chips but removing the dpf and egr might not be in a good idea since here in japan it can be strict in that regard, i saw a bunch of companies offering performance chips, mainly, madness, racechip etc, any brand you would recommend worth getting?To answer your question I remaped a few 210hp Stelvios. Stock only with remap you can get around 40hp more.
Then you can remove DPF and both EGRs. After that turbo upgrade and adding the water coolers from 280/510versions... the Q2 mechanical diff if you don't have it, 6 pistons front brake calipers and so on.
located in niigata cityWhere are you located in Japan?
