Ok, not going to do a full write up on replacing the plugs, the basics are covered. Just want to add a few tips and tricks, then discuss wear.
Tools needed: pick, a 10mm socket with a 3in extension, a 16mm or 5/8 deep socket or spark plug socket with a total of 9in extension. Also a magnetic bowl to hold bolts securely and an extendable magnet to grab any bolts that might fall, these arent nessesary, but can come in handy.
Tip #1 electrical connectors.
Use a pick to pull or push the grey levers. Push down while moving the lever. Push down on the grey lever also when removing and replacing the connector. The lever has a hook that clips to a plastic part on the coil pack to lock it in place. The plastic piece on the coil pack can break off if the connector is forced (or the hook on the lever can break, both bad) never yank or force anything when removing electrical connectors...or in general when working on a car.
Besides the connector on the packs you will also want to remove one connector above the second cylinder (from the front) to make removal of the coil pack easy. Pull the red clip forward, then press down on the black lever in the middle of the red clip, and remove easily.
2 Removing/replacing bolts and plugs.
When removing do not yank or hit. Use even constant pressure, start easy and increase the force you use slowly till something moves. Same thing when replacing the bolts/plugs. Tighten till snug, do not ever crank down as much as possible.
Also - very important - the plugs should thread back in very easy. If there is any resistance, before the very end, when turning: back them out and reinsert. DO NOT CROSS THREAD. This car has an aluminum head and it is easier to do then you might think. Do not use threadlock of any kind.
This is why I suggest these extension lengths. Last cylinder clearance.
