1 - 20 of 46 Posts
Alfa romeo 164S, Giulia ti Sport Q4
Start/Stop Deactivator for Giulia/Stelvio- PRE-ORDER (Available ~ October 27)- $89.00 for pre-orders.
Deactivates Start/Stop. No more trying to remember to push the off button. This is a real deactivator, comes with plastic wedge tool and instructions to install.
Dedicated PCB, product quality/roboustness/tidy design and 1 minute Plug & play
This is not a cheap design with wires and resistors made in China.
Made in EU by an electrical engineer.
https://alfissimo.com/home/1640-sta...telvio.html?search_query=SSD-20-17&results=10
We all should ban together and boycott this start / stop button. They only do it to increase the window sticker MPG so we suffer for so they sell more cars , They all do it so we all should do it . Makes me want my 2010 Volvo back
I hate the dang thing too...but it's not that big of a deal.
I've training my start-button-finger to hit the deactivator
right after I hit the start button.
I forget sometimes when I use remote start for some reason..
Discussion Starter · #7 · (Edited)
'comes with plastic wedge tool'
to hold the button in?
To safely remove headlamp control panel. It's a plastic pry tool used to remove interior parts. Included with unit in order to cleanly remove it with damage. Making it easier. ;)
Item has been thoroughly tested.
Some will rather have this than have to think about it every time you get in the car. Either method works.
Better overview:
Currently manufactured cars are equipped with start&stop (S&S) system. It is used for reducing emissions when the car is steady. Unfortunately, practical operation of S&S has multiple disadvantages, especially in cars with an automatic gearbox. In most cases users experience redundant, short engine off/on toggles just for a few seconds, as they have no influence on the moment when the system kicks in. Such toggles are not only inconvenient, but sometimes a bit dangerous – for instance when a car is approaching a main road where visibility is limited and the car needs to be stopped. The engine is stopped by S&S system. Driver would like to be able to immediately join the traffic, but engine restart adds potentially dangerous delay which works against doing traffic join safely.
Aside of this, when S&S kicks in, the climate control system does not work efficiently and the car battery is additionally discharged (car lights, wipers, radio and additional engine restart), which results often in a non-optimally charged battery.
Although the car manufacturer has provided a button for the deactivation of the S&S system, its last state is not stored – the next ignition toggle restores the S&S system back to an activated status, and the driver needs to remember to turn it off again.
Use
SSD952.949 device is used for an automatic S&S deactivation shortly after an ignition is turned on. It is compatible with Alfa Romeo Giulia 2016+ and Stelvio 2017+.
Installation (plastic pry tool and instructions come with unit) takes about 2-3 minutes.
Device use
SSD952.949 comes configured to disable the S&S as a factory setting after the ignition is turned on. In case the user would like to temporarily enable the S&S operation, it can be done by the car’s S&S button press. After next ignition toggle the SSD952.949 will disable the S&S.
A non-volatile deactivation of the SSD952.949 device is also possible. To do so, it is necessary to carry out 8 presses of the car’s S&S button with a delay not shorter than 1 second and not longer than 3 seconds. Successful deactivation is indicated by 8 blinks of the car’s S&S light on the panel S&S button.
In order to re-activate the SSD952.949 device repeat the same procedure as for the deactivation.
Other notes
Each SSD952.949 device passes hundreds of electrical tests on an automated tester, as well as randomly selected production samples are visually screened and mechanically checked for robustness, what guarantees top quality of the final product.
Warranty and other claims
We provide a 2-year warranty for the SSD952.949 device failures. We reserve the right to reject a warranty claim in case of damages caused by an improper use, such as the use in harsh environmental conditions, water or other fluid swamp, contact with aggressive chemicals, damage made by the user, attempts of opening the device housing/connectors or any other modifications made to the device.
Do not use the device if there is visible damage, or in any case if you suspect that the condition of the device is not good or the device presence causes any car system to misbehave.
My start/stop is automatically disabled because down here it's always hot outside so we always have our cars' a/c temperatures down to the lowest possible setting. Apparently if you set the Stelvio's temperature to Lo, start/stop is automatically disabled. Obviously this solution won't work for people who live in states that have actual winters
Let me know when you make one of these for the seat belt buzzer, much more annoying than start/stop especially when I'm just looking for a spot in a parking garage
From memory I think this can be deactivated in 2019? Either by MULTIECUSCAN or in the infotainment controls.
If not, some people used a seatbelt extender, More convenient for using the belt(s) as well, as they are more easily accessible ... ;)
https://www.amazon.com/Seat-Belt-Extender-Extension-Certified/dp/B07YCD329J/ref=sr_1_28?keywords=car+seat+belt+extender&qid=1571744021&sr=8-28
I wouldn't trust this product with my life so I use a "blind" adapter that just turns of the warning sound when only driving slowly, e.g. through the woods.
That doesn't protect you from other people hitting you though ..... ;)
I just wear my belt.
It's now just simply apart of my routine every time I start it up. I wish it wasn't but you get used to it after a while.
1 - 20 of 46 Posts
