1 - 14 of 14 Posts
Hi There, just 7000 km, 6 months and have message "change oil".
Manual says 15000 km first service and oil change. Does Stelvio have oil quality sensor or it is just computer fault. Oil level is OK according to car screen display.
Any advice please.
Cheers Jedrek
There is NO oil quality check. Most likely software or oil sensor issue. Do you have the latest software update?
The oil change indicator turns "on" using several factors.
From miles driven to type of driving, average speed, number of stops, amount of idle vs steady cruising, altitude, air quality (the amount of air pollution affects how often the oil need to be changed), and more.
The Stelvio (and pretty much all cars) do not actually test oil quality - not only because viscosity breakdown is the worry more than dirt now and that isn't easy to test for - however the light isn't just a "dummy" light either.
It could be the algorithms are wrong or malfunctioning, or it could be the type of driving you do means the oil should be changed sooner. Either way good idea to get it looked at by the dealer.
Same thing happened to me. The recommended oil change is 10k miles or 1 year. I only had the car about 7 months. The timer must start when it leaves the factory or something. Dealer just reset it and I went back in for an actual oil change when I hit 10k.
I don't know if I would just trust resetting because the oil light decided it was time, but you had not hit the threshold yet. Usually when people do actually test oil, depending on additives and formula, there is usually some miles left at the recommended interval. I wouldn't take that chace though. An oil change is cheap compared to major repairs.
Same here.
Dealer reset it when they did the recall a few months ago. Finally hit 10K last week.
I had like 5,000 miles on the car. This same thing has actually happened with numerous people. The light goes off due to the 1yr time frame but unfortunately that timer starts way before anyone actually drives the car so it's unnecessary to change it so early. This has been confirmed not only on this board but also with the services techs at the dealer.
There are a lot of variables that go into when a car needs an oil change.
Generally, unless it is NOT a "free" oil change, the only thing the dealer looks at is if they "have to do it" (picture a 10 year old being told to do homework), or if it can be put off. If it is under 10k, they will put it off if you let them. Amazing how if you offer to pay they will jump at the job though.
Does that mean it should be put off?
Don't really know.
In my opinion, for lots of reasons no one actually wants to read so I'm going to not spend time writing, an oil change should never be put off. The suggestion isn't 10k miles, it is 1 year, or 10k miles.
The year starts when the oil is put in the engine, not when you buy the car.
Experts and labs says lots of things about minimums and life left and stuff with things on top for smartness. Then when something breaks they talk about statistics for expected failures and it being within the norms.
The mechanics who have scarred forearms from fixing stuff all agree, avoiding the break, regardless of "norms" is best..never put off an oil change if you want a long life out of your engine. Never, and 10k or a year is a little long. I did my own at 5, then the dealer at 10. About to turn 15k, going to change it again. Oil cannot be too clean, the cleaner it is the better your engine will run, period, no exceptions to this rule. Dirty is the same, dirty oil is bad, period.
How dirty? Don't care, doesn't matter.
How old? 1 year. just because it was sitting doesn't mean the factors that cause viscosity breakdown weren't happening. In many cases they are worse, engines and the oil inside them are highly engineered for long life under use, not long life while sitting.
Think about it this way.
Super smart people have Orange County, Ca convinced "toilet to tap" is a good idea (yes, they filter defecation out of sewage and put it back in service as tap water), because they ran taste tests and people liked the taste of the filtered poop water more than straight tap. Plus those super smart people are super positive the filtration tech is perfect and there can't be a health crisis from this. Thing is, they figured out even if it gets all bacteria (I doubt it, we'll discover a new strain it doesn't get eventually) it doesn't get drugs. So all the prescription and other medicines people take that get moved out of their system...that stays in the water. All the drugs flushed during police raids...stays in the water.... You may disagree, but personally I run everything smart people tell me through a "common sense" filter.
Common sense says don't drink water that has been pooped in, and change your engine oil often, both for a long trouble-free life.
Oil Change interval
How aggressive is your driving Jedrek and do you idle alot or make short trips that might not allow the oil to heat up enough to boil off the gasoline from it?
The main factor in viscosity breakdown is thermal but if the vehicle is non-operating (sitting on the dock/boat, etc) for it's first 5 months then that isn't happening. How would it be worse from sitting in a brand new engine versus normal use? Normal use is what introduces the breakdown.
Contamination is the issue. The oil itself isn't at issue, it is everything that contaminates it.
https://www.amsoil.com/newsstand/motor-oil/articles/why-motor-oil-deteriorates/
Any advice please.
Cheers Jedrek
I think it also depends on the manufacture date. If the car has been manufacture more than 12-13 months ago it will trigger an oil change even if you have only 5k miles on it. Similar thing happened on my S5.
@pyrrhusm nailed why oil siting is bad.
The important thing to remember is the MAIN reason for something is not the same as the ONLY reason for something.
High heat breaks the oil down faster, thay's why when used oil should be replaced after a certain amount of use, not time span. (Assuming the use happens before the time span.)
Time span becomes a factor when not used.
I would add to the article... the chemical reaction between the oil and the metal in the engine, added to temperature variations and atmopheric moisture also contributes to oxidation and breakdown.
Point is, the best idea is to replace it 1 year from when it was put in the engine, or 10k miles whichever comes first.
We have the same issue. We have had the car for 3 months and put 4,000 miles on. The computer says I need to change the oil in 29 days or 5,500 miles. I agree with the mileage number, but I suspect the timing is off. The build date was 7/17, so there is a lot of history from 7/17 to 3/19 when we took delivery. I am assuming the dealer should have reset this at delivery, but it actually was reset in the past when they did one of the recall repairs. I plan to stop in next month and have them reset, or do an extra free oil change if they like.
1 - 14 of 14 Posts
