It would appear we all have pending recalls on our vehicles; see the other thread on "Stelvio Safety Recalls"; 2 issues actually - which I have copied here for you (as as noted, they don't have parts available yet):
#1 - Safety Defect/Non Compliance Description and Safety Risk
The A-pillar sheet metal joint and plenum sheet metal to the heating ventilation air condition box may experience sealing deficiencies which could result in water intrusion and subsequent corrosion in the body control module A pillar connector and/or body control module component. This corrosion may result in one or more malfunction indicator lamps (MIL) and/or a loss of windshield wiper function, and/or a loss of all exterior lighting, and/or loss of horn function and/or inadvertent turn signal activation. In certain cases, a MIL may illuminate indicating the issue. In certain cases, a MIL may illuminate indicating an issue with the windshield wipers, auto headlights not operative and/or external lights not operative. In certain conditions, loss of windshield wiper function and/or exterior lighting may reduce driver
Repair Description
Install additional sealing protection to prevent water intrusion for the body control module A-pillar connector and body control module.
Recall Status
INCOMPLETE BUT REPAIR PARTS ARE NOT AVAILABLE
#2 - Safety Defect/Non Compliance Description and Safety Risk
The rear liftgate may experience deficiencies in the sealing and water management system in the rear liftgate applique and rear tail lamp that can result in water intrusion and subsequent corrosion in wiring connectors in the rear liftgate wiring harness and the liftgate-opening switches. This corrosion may result in an unintended activation and opening of the rear liftgate door at vehicle speeds up to 3.1 MPH (5 km/h). An unintended activation and opening of the rear liftgate door may result in a loss of unrestrained cargo. Lost cargo may create a road hazard and could cause a following vehicle to crash without prior warning.
Repair Description
Install additional sealing protection to prevent water intrusion for the rear liftgate wiring connectors and switch.
Recall Status
I'll keep an eye on both areas of the car in the interim. Such is risk of buying a brand new model of vehicle.
