Many folks here have purchased the 265/45R20, 295/40R20 combination and found vastly improved ride quality, looks and AVAILABILITY. I have Falken FK510s on my Maserati GTS and they are a new favorite tire. Fabulous in heavy downpours last month. They held up to a track day last summer far better than the PZeros!! Their drivability does not fall off the cliff below 50 degrees either. I safely drove the GTS in low 30's last week and the tires still did their job .....and yes after my pZero debacle, I tested them aggressively. Especially when you factor in the price, these should be a no brainer option for someone looking to retire their PZeros but they still want a Max Perf summer tire. Ride quality is improved due to larger size not a softer tire. I have emailed Tire Rack to inform me when the next Falken special is run so I pick them up for next spring. OD is in the 29.5/29.4 range which is identical to the OD on my winter setup. Speedo is spot on perfect. Weights are 30/33lbs just like stock, so not heavier like a bunch of the AS options I researched esp the portly Toyo STIII's. Fronts only 1lb heavier due to size
In winter I run 245/50R20 and 275/45R20 Michelin X-Ice. Same OD as above. They were fabulous last winter NO ISSUES. Tire Rack at first did not want to sell me these sizes, but after I installed them, they signed off on the fitment as an ideal winter choice for the stock Quad wheels. So keep these in mind folks
