I think those actually use screen integration though, so you still need the Alfa infotainment to access all the car settings etc.Actually they sell the headunits that looks very similar to 2020 on alibaba. Touch screen, wireless carplay etc...
I think they sell it for 900 to 1300, all android based. I bought just the switch for the 2018 radio to have wireless carplay. I think they sell those for 300 or so now... bought mine 2 years ago for 600
It indicates it has subwoofer control, interesting. Does seem like a bit of a gamble.Here's one I found. looks like this is a complete unit with the screen.
krando radio Not sure if I want to do this but it's an option. I believe these units intergrate with alfa car settings. I never bought anything from alibaba but I do know that some has.
I've bought 1 and try to need some translation from the guys, they deliver it without manual or discription how to connect.Here's one I found. looks like this is a complete unit with the screen.
IR - Infra red for a receiver so you could use a remote with it would be my guess.I've bought 1 and try to need some translation from the guys, they deliver it without manual or discription how to connect.
Just screen, wires and 2 antenna's in the box.
Most is plug in, except 4 wires.
No idea what the brown and blue wire is for. lol
And the IR is mentioned for "In reverse" or "Infra red" lmao
Good luck with the install. Please update this thread if and when you get it working. I am particularly interested to know if the headunit increases the audio quality at all and how the mic works for phone calls, thanks!I've bought 1 and try to need some translation from the guys, they deliver it without manual or discription how to connect.
There is no powered antenna .. 1 sattelite and 4g antenna and no infra red on itIR - Infra red for a receiver so you could use a remote with it would be my guess.
ACC - Should tell the radio the car is powered on. It goes to ignition or cigarette lighter type source.
Blue could be for a powered antenna
Brown?????
I would wager that you do not need to use them.
I know your right what I am saying is that could be what the wires are meant for. Remember they use the same internals for several different cars and the outer interface is what is modeled after factory. I had similar systems for my F150, Mustang, and Accord. They all had those similar extra wires that were not used most of the time.Here you see a part of the installation.
Yep so true ... II know your right what I am saying is that could be what the wires are meant for. Remember they use the same internals for several different cars and the outer interface is what is modeled after factory. I had similar systems for my F150, Mustang, and Accord. They all had those similar extra wires that were not used most of the time.
i know but connect 1 wrong one and your ECU is toast and this is a part of it what lots of people forget.you only have 4 wires ... i think I had close to a dozen all labeled in chinese which were not part of the install.... think most were for speakers.
more reason to just plug in and leave the wires alone?i know but connect 1 wrong one and your ECU is toast and this is a part of it what lots of people forget.
That's why you can't use a 2020 screen on a 2018 Stelvio, all sensors and ECU is different.
How would you rate the unit? These guys told me that the unit does not work 100% with 2018 and 2019s. I am looking at another one.I've bought 1 and try to need some translation from the guys, they deliver it without manual or discription how to connect.
