hi. I live in Toronto and do a lot of driving to ski hills. I always put winter rubber and dedicated rims on my vehicles. I just bought a 2018 base model stelvio w 18" wheels. Does anyone have recommendations on wheel sizing for winters?
Tire manufacturers no longer recommend going narrower with the improvements in snow tires. For the same reason as you want wider summer tires, it's all about the contact patch gripping the snow and ice.I usually go with what the dealership suggests in size and go for Michelin tires. Never really thought much about it, though I have heard that tires that is both smaller in diameter and narrower than your summer set has better grip in the snow.
The wider the tire's contact patch the worse it will be in snow. Think about how snow shoes distribute your weight on a wider area so that you wont sink in the snow. Same principal.Tire manufacturers no longer recommend going narrower with the improvements in snow tires. For the same reason as you want wider summer tires, it's all about the contact patch gripping the snow and ice.
I understand your logic for saying this and it was true years ago before winter/ ice tire technology took a massive leap forward.The wider the tire's contact patch the worse it will be in snow. Think about how snow shoes distribute your weight on a wider area so that you wont sink in the snow. Same principal.
The narrower patch concentrates more down force on a smaller area hence more traction.
The same reason why you'd want weight distributed with a snow shoe is the same reason you want a larger contact patch with a tire. You want forward motion not downward digging.
This is what Continental says about it, but all the tire manufacturers say the same:
Wide tires
Cheers!
Hi, I just installed my winter wheels on my Giulia.Has anyone found aftermarket rims for the Stelvio?
I'm trying to find winter wheels and tires but have not found anything that fits.
ET34 for the Stelvio 18 x 8. It seems to be the 65.1 centre bore that I cannot find.Hi, I just installed my winter wheels on my Giulia.
They are replica 18" wheels by RWC wheelsRoues d'hiver, a Montreal based importer.
They make this model in silver and anthracite, 18x8 ET30.
The wheels have an offset of 30 which is exactly in between the wheel offset of the Stelvio and Giulia.
The Giulia has an ET33 offset and I believe the Stelvio has something like ET27....
This wheel will be a perfect fit for the Stelvio,
It is engineered to be direct fit on your hub with original bolts and centre caps.
Not too expensive either!
Check it out
These wheels are 18x8, ET30, CB65.1.ET34 for the Stelvio 18 x 8. It seems to be the 65.1 centre bore that I cannot find.
Thanks for the link!
I installed 225/45/18 Nokian Hakkapeliita R2Nice. How much were the wheels? (I didn't see pricing on the linked page.) What tires did you install?
