61 - 76 of 76 Posts
Tonight I enabled TJA and LKA (xx10xxxx) and it worked as expected. Pressing the TJA button, then ACC button, setting a <35mph speed with lane markings present steered the car. It worked okay. It disabled itself many times when it was unable to detect the lane markings. Still curious what Active Lane Management (xx11xxxx) is if anyone knows.
I also enabled wipe auto wipe but it didn't seem to work. Ill have to check the proxi values again.
Could “active lane management” equate to the Infotainment setting under Lane Keep Assist that bumps your steering to keep the car between the detected lane markings? Just guessing.
Which trim cars can have the LKA? With the base model, if I would activate ACC, I would have the LKA as well?
For LKA, I believe you need to have active blind spot assist which includes the steering wheel motor and can steer the car when a car is detected in the blind spot. I believe the LKA also relies on the front facing camera which is included if your car has forward collision warning (FCW). My 2020 Ti Sport has these features.
LKA and ACC are separate settings/proxi values in MES. You can enable one without the other.
i have a my2020 Stelvio with lane departure warning, fcw and acc. I bought the steering wheel with the touch sensor and i wanted to install it to enable LKA and TJA, but i dont have blind spot. why do you think blind spot is necessary for LCW? this alfa romeo official video explain it uses only front camera:
I don't see why/how LDW/LKA/TJA requires any incremental hardware that Blind Spot Assist also requires that FCW doesn't require. So I'd say try it?
loheiman,帖子:218860,会员:21864 said:
今晚我启用了 TJA 和 LKA (xx10xxxx),它按预期工作。按下 TJA 按钮,然后按下 ACC 按钮,设置 <35 英里/小时的速度,并在车道标记存在的情况下驾驶汽车。效果还不错。当它无法检测到车道标记时,它会多次自行禁用。仍然好奇主动车道管理(xx11xxxx)是什么,如果有人知道的话。
我还启用了擦除自动擦除功能,但似乎不起作用。我必须再次检查近似值。
[/引用]
xx11xxxx需要用官方witech来编写,但前提是你的车辆需要有自己的导航系统。
Has anyone ever tried this on a 2020 Stelvio? I wanna do this so badly but also sh*t scared. I see the ACC button layout has changed for 2020, Does this mean anything while Reconfiguring the Multiecuscan?
Is it possible to do the same with Lane keep Assist and Lane Departure Warning? and I am unable to get hold of the ACC button part anywhere. can you advise? Thank you very much @KGB.
hey did you manage to enable the adas you wanted?
Hello all!
I own a 2019 Stelvio with many 2020 upgrades (ETM, TFT, Touch, Body Computer, Tunnel, Front Camera, Steering Wheel).
My stelvio was equipped from day one with ACC, LDW, BSM, FCW and I recently activated the Traffic Sign Recognition feature.
Now I'm trying to install the other ADAS 2 to my Stelvio (Lane Keepeng Assist, Traffic Jam Assist, Highway Assist, Intelligent Speed Control and Driver Attention Alert.
For this purpose I installed the new steering rack motor and changed the left button panel on my steering wheel with the new one, my steering wheel is a heated MY20 with hands presence sensor.
With MultiEcuScan I have changed the byte 166 to "AF", but none of the adas are activated.
In the display I see all menu entries and i have changed to activate new features, but none of them works.
The Lane Keep Assist just added an option to vibrate my steering wheel, instead of emit an acoustic signal, but the keeping function is not working.
The intelligent speed control are activated in the menu, but when the cruise control is engaged and i am at a higher speed than indicated on the signs, the green arrow does not appear on the TFT.
The Driver Attention Alert does not engage when i leave my hands from steering wheel for more than 10 seconds.
When I press the traffic jam button, on the TFT appear an error to check the "Traffic Jam Assist".
What am I doing wrong? Do I need to do anything else?
Thanks all!
61 - 76 of 76 Posts
